F115 Running rough
  • F115 Running rough
    Runs rough like it is starving for fuel. I checked and cleaned 3 filters before the high pressure pump. I get 42 psi on the fuel manifold which does not very much with rpm. Should the pressure go up or down with rpm? The plugs look good.
    Usually about 38 lbs at wot.
