I have a question if the wrong plugs could do this kind of damage. 96 200 saltwater had been running good but gave it to my mechanic for maintenance, plugs, impeller, lower unit fuel sep, etc. Since I got it back acting up. Runing good for a while then bogged down like rpm reduction but no alarms. Had mechanic look at it and said something about idle stall or timing. I checked the plugs and 2 were destroyed after only 2 times out in the water. Also noticed they were not the right # for the motor. looks like bottom portside has hole in the top of the piston. please help!
please help detonated piston
