225 Saltwater Series II--Low comp??
  • 225 Saltwater Series II--Low comp??
    98 225 SWS II--running like it was not firing all 6--Has now lost top end rpm--engine has 23 hours on powerhead. Compression on left bank--96--65--98
    right bank--100--95---100. Can this be anything other than rings/piston?
    The compression was checked with all 6 plugs out and warm.
    H20SKE...
    for the minium cost of a headgasket you should pull the head and check cylinder walls before any more possible damage is done.
      This unit is a rebuilt unit with a warrenty on it, so I am hoping the facility I bought it from will step up and cover this.
      I have 18 years as a Automotive and diesel mechanic, so I am a need to know person, I have basic 2 stroke knowledge, but not alot.
      To my knowledge when comp is down like this--it means piston and rings at least, Does this require a full tear down or what to accomplish this repair??
      I do not like being in the dark when taking it in for someone else to work on.
      You all helped me on several other questions on this unit--the overheat issue.
      Thanks, H20SKE...
        Be careful not to void the warranty when performing your inspection.
          Thanks for the warning--I am not taking it apart--just doing checks that can not cause a issue--not opening up the motor.
          Thanks,H20SKE...
