I have a problem with my engine that has left me and my local Yamaha dealer out of ideas.
The engine starts and runs smooth. when running at 5000RPM for 15 minutes or so the engine starts to lose power, the RPM will drop to 4500 down to 3000RPM within minutes. it runs fine once the revs have dropped to 2500RPM.
If you prime the fuel bulb it picks back up to max revs for a couple of minutes, then loses power again.
I have renewed the fuel filter and all fuel lines from the tank to the two pumps to no effect. I have also renewed the diagphrams in both pumps and last week connected a remote tank directly to the fuel filter on the outboard but this hasn't cured the fault.
My dealer has also stripped, cleaned and balanced the carbs but this had no effect.
Any help would be much appreciated as I am now struggling to think what else it could be, and my boat is parked up in the good weather.
Many thanks in advance,
Gaz
Gaz
