removing fuel strainer???? HPDI 150
  • removing fuel strainer???? HPDI 150
    have a 2002 HPDI 150. the bottom of the fuel strainer located just above the evap has a chrome/plastic coupling which for the life of me i cant figure how to disconnect. Anyone?
    Answer to the question
    So I've got it... first let me clarify- The motor is a Z150txra and this is the strainer on the fule line just infront of the vapor separator.
    The feed line connector is a quick connect coupling.
    Simply pull the connect toward the strainer and on the bottom of the connect there is a black plastic sleeve. with a small flathead push this up into the coupling and the strainer will slide out from the connector.
    CA
