Yamaha 703 Con*****er
  • Yamaha 703 Con*****er
    I recently bought a boat with a 7-pin 703 con*****er. Unfortunately it doesn't have a key. How would I go about obtaining a replacement key?
    Thanks!
    Wag
    Remove the key switch and look on side of switch barrel for key number.
      Thanks for the reply. I guess the only way of removing the key switch is to actually remove the con*****er from the hull and open it up, right?
      Wag
        Yes, you may be able to read number by removing nut thats holds switch in control box. You can take it to your dealer and ask them to find a key that works.
          Thanks again.
          Wag
