I have a Yamaha 175 HPDI 2 stroke. I removed the housing on the water pump to replace the impeller, however, I could not get the woodruff key to come out. It is stuck firmly into the shaft, and I need to remove it in order to replace the gasket below the impeller. Any suggestions?
Stuck woodruff key on water pump shaft
