2001 f115 txrz water in oil???
  • 2001 f115 txrz water in oil???
    Any help welcome to this problem, engine runs great no problems,oil leak at driveshaft,water in oil,some not mixed,water comes before oil at drain plug,r&r head for possible head gasket problem,none found,run 3 hours water in oil,never overheated pissin fine, no alarm,run with cover off no water going in oil stick,r&r engine for oil leak andchecked adapter plate gasket,nothin I can see,am Imissing something?recall? Mike
    Oil pump may be leaking and need replacing.
