motor slips and grabs
  • motor slips and grabs
    I have an 89 Ranger 393 with 225 excell when i trim it up it will slip for 4 or 5 seconds then bite again . It goes back and forth. The Ranger has two steps underneath and the cavitation plate is about 1 inch higher than the bottom of the transom. Should it be even with the bottom of the boat or the transom?
    You might try to lower motor one hole to see if helps.
