1999 V225X with digital fuel gauge. When I purchased earlier this year on 2004 Paramount 21', the gauge worked properly. The first time I filled up, the gauge flashes one bar (near empty), and continues to do this even though I have run offshore and back several times. Is this electrical or is float stuck?
fuel gauge flashes one bar always; 3.1L VMAX
If you can get access to the sending unit in the tank ground the two wires together and wait a second and see if the multigauge fuel quantity shows full. If it does then the problem is a faulty sending unit in the tank. If it doesn't then it could be a disconnected wire on the back of the gauge or somewhere in between. Its most likely the sending unit in the tank. Stock float type sending units are prone to failure. I switched to the Centroid electronic sending unit and it's been super reliable. Here's a link to their site: http://www.centroidproducts.com/tableofc.htm . Once you get it calibrated (easy) it will be very accurate and reliable. Get the two wire sender and (5) 5mm x 30 stainless machine screws from the hardware store and it's about a 10 minute install job. Good luck.
Mike
