fuel management system--user's guide/manual
    need fuel management
    can you send me the manuals THANK YOU. fuel management system.
    e-mail (gp113s@sbcglobal.net) thank you so much...
      Fuel Management System Wiring to GPS
      Hello,
      I am looking for a wiring instruction for the digital Yamaha Fuel Mgt. System on a pair of '97 L200 SWS II motors. I need get speed info sent from my GPS via NMEA 0183 to the FMS. Please email to rogerl@qualcomm.com.
      Thank you for your help,
      Roger
        fm sensor
        were does the white with pink stripe and black wire go from the fuel sensors?
        part 6Y5-83553-F1-00
        Originally posted by Hamfisted View Post
        About the only thing you can do is reset it to zero when you fill up the gas tank. To do that just turn the ignition key to the "ON" position, do not start the motor, then push the two buttons down together for a few seconds. You'll see the totalizer reset to zero. Other than that just cycle through the MODE button to pull up whatever's available. If its not connected to your GPS or Speedometer output you won't see any other info other than gallons per hour and total fuel burned since reset.
        -Mike
        • #19
          fuel managment manual
          Hi Could you please send me a copy of the fuel managment manual please many thanks
          • #20
            Could you please send a copy of the manual to massimo_salamone@hotmail.com
            Max
            • #21
              need manual to install
              hi by the looks of it someone has the manual now for the fuel managment gauge if some could forward the wiring diagram to my email that would be great thanks sparksy1981@hotmail.com
              • #22
                I need the manual for my round type fuel management meter (no speed) to mboren@ssi-net.net thanks
                • #23
                  Here is manual,
                  Yamaha FM Gauge.pdf
                  For operation information look at your outboard motor owners manual, owners manual can be viewed on Yamaha's web site. www.yamaha-motor.com
                  • #24
                    Yamaha gauges manuals
                    hello everybody, to know more about the gauges, here is the PDF link
                    http://www.yamahaoutboards.com/sites...al(Square).pdf
                    regards.
                    Ali
                    • #25
                      can you send me the installation diagram but I need the one for PRE-Command link.
                      • #26
                        Yamaha Fuel Management System for twin 115 hp
                        Can I get a copy of the wiring diagram for the Yamaha Fuel Management System for twin 115 hp motors
