when should you change a water pump on a 2005 60hp 2 stroke? allso is there a prv on that motor part # do they make a water pump kit or do you have to by each peice
water pump
I like to change the water pump every other year, or at the most, every third year , depending on how much useage I put on the motor. You can get the waterpunp rebild kit here at this web site, they have the best price that I have forud. find your motor, and parts breakdown, to get the correct part number, on there parts page.
Dennis
Here is the link to water pump repair kit http://www.boats.net/parts/search.ht...7CREPAIR+KIT+2
692-W0078-02-00 Water pump repair kit without housing
That engine does not use a pressure control valve just a thermostat.
