1999 ox66 250
  • 1999 ox66 250
    Port side motor just cuts off. You can run any rpm and at will it will cut off, it may go fifty miles or two before cutting off. I swaped the CPI from port to starboard and same results. The motor will restart after about two minutes, it never gives a alarm. Thanks in advance
    next time you run it..... unplug main harness, see if it does the same or not..... this isolates the motor from harness/keyswitch/controls.
      Dumb question
      Main Harness would be which one? Thanks
        10 pin, large
          I guess this would be in bott of cdi?
