i have a yamaha 150 2 stoke with a 704 remote con*****, everything shifts great, the only problem is when i push the throttle foward its slipd back to a lower rpm. is there any way to tighten the cable.
yamaha 704 remote con*****
Cover screws frozen
I went to check my friction adjustment and learned 3 of 4 of the cover screws are totally frozen.
There is no space to shoot PB Blaster. Should I cut the heads off or unbolt the control from the console to gain access to the cover screws.CBO
1991 Boston Whaler Outrage 17 I
2003 Yamaha F115
The throttle friction screw is not on top of control box, it's in the back of control at an angle.
The screws holding cover will probably break off when you try to unscrew them. The flange the screws go into will unscrew from control box to remove broken screws.
Yes it is. Remove the plastic cover and it's on rear of control at bottom.
