I flush my outboard with salt terminator. It comes with a cup attachment that connects to your hose flusher.Just pour some of the salt terminator in the cup and as the water is flowing through the engine block, it breaks down the salt build up.You can see the foam coming through the exhaust at the prop.I use it after every use. Safe boating.............
