Yamaha Fuel Management System
  • Yamaha Fuel Management System
    The fuel management gauge shows all zeros. I checked the connection on the sending unit and it is clean and free of corrosion. Can I assume that it is the sending unit because the gauge appears to be working.
    unhook hoses at sender, blowing thru will create MPG's....if working, could be clogged also.
