Fat Blue Green trim wires on relay?
  • Fat Blue Green trim wires on relay?
    The Large/fat green an blue trim wires were completely removed from the relay. can someone tell me which terminal these connect to on the power trim relay. Which bolt of the 8?
    In addition my ptt is pretty corroded. Can these relays be taken apart to clean inside? If i was to replace the relay which one do i need? I have a 2001 Z150tlrz 2 stroke
    The relay should have green paint on end of terminal that the green wire connects to and blue paint for blue wire.
