Originally posted by 99yam40
View Post
With the weight of the balancers/forces needed to spin it, Yamaha dropped the ball with the initial design of it.
Also agreed, if my engine had that failure, I'd be pissed too. Eventually Yamaha stepped up and is replacing the older, bad balancers.
Re the engines already damaged with debris floating about the powerhead, Yamaha should step up and make things right. Should it end up in court, Yamaha's going to be footing a big bill for those (like the Ops).
*I can say, Yamaha, at least in the motorcycle world, has been good with fixing bikes with known issues even when they were literally YEARS out of warranty.
The TPS on certain years FJRs and FZ6's (early to mid 2000) were sometimes faulty and will to this day, replace the TPS on a bike 9 years old. On the 2003 FJR and certain 04 FJR's (a large sport touring bike), the exhaust valve seals / guides were too tight and the engine would eventally develop a "Tick".
Yamaha, to this day, if you brought in an 2003 "Ticker", will do a full valve job (exhaust valves) to fix an 11 year old bike..
