help please f100aet milky oil
  • help please f100aet milky oil
    hi i have a f100aet and found milky oil in sump when checking oil engine running fine upto oil check no smoke , someody said head gasket , pulled head no probs there , then advised oil pump seals, removed power head ok, removed lower unit ok , but cannot get sump unit off, seems to be stuck on the shaft but have no book and i live in samoa very hard to get anything here.
    any ideas welcome
    regards
    Ian
    Here is the parts listing that might help to see if all the bolts are out.
    http://www.boats.net/parts/search.ht...7%7C%7COIL+PAN
      thanks
      thanks for the link to the diagram, but i still cannot find a way to get the oil pan down, it seems the whole unit is commected to the shaft behimd it, i cannot see a way to release it.
      thanks again foryour help
      regards
      Ian
