Second Key switch
  • Second Key switch
    I have a tower and want to instal a key switch up top, will i need any specal parts? or just a second key switch that can wire into the one down below?
    will the standard 704 switch be all i need?
    2007 yam f250 engine
    You can use the push button switch panel(6X1-82570-00-00) thats used in the dual station kit but you would need to do all the wiring to it as the wiring harness(6X1-8258A-20-00) thats used in kit is for the actuator and junction box as well.
      yes but will the standard 704 switch work with out any additional harnesses etc? just requires manual wiring?
        There is no wire harness available to install just a switch panel. If you use a 704 switch panel then you have to turn upper station switch and lower switch on in order to run motor. Push button switch are easier to use.
