calibrate fuel management
  • calibrate fuel management
    how do you calibrate the fuel management gauge ?
    thanks
    Dip switches on the back....
    If you look on the backside of the gauge you'll see a rubber/plastic plug covering some dip switches. Use these dip switches to calibrate the gauge as necessary, although they're usually pretty accurate from the factory.
    -Mike
