Multifunction Speedo Fuel Management Guage?
  • Multifunction Speedo Fuel Management Guage?
    Will this work with 1991 twin 250's?
    WHat is the part # of the guage in kits 6Y5-W0088-70-00 and 6Y5-W0088-80-00. Is it the same guage with different harness and extra sending unit?
      Yes it will work on 91 250's. The part number of gauge is 6Y5-8350F-00-00 in both kits.
        I am interested in the speed fuel management combo guage. Will that plug into my '91 harness and replace the speedo? What is that part #? Thanks
          6Y5-W0088-80-00 is the Speed/Fuel mangagement combo kit. 6Y5-W0088-64-00 is the Fuel management kit for dual engines.
            Is there a speed/fuel combo kit for twin 91 250s?
              6Y5-W0088-80-00 is the speed/fuel combo for twin 250's.
                Thanks, will it plug into my existing speedometer harness? Will the combo guage recieve info from the GPS like the seperate guages do?
                  Yes it will connect to your wiring. You need to order optional 6Y5-85721-F0-00 signal lead to connect to GPS.
                    6Y5-85721-F0 Signal lead for GPS is rather expensive.
                    The only wire hooked to the GPS is Port 2 Data Out. It is very thin wire and having an expensive signal lead to the Fuel Managment Gauage 6Y5-83500-40-00 (BK) appears to be an overkill.
                      6Y5W00886400 on a SINGLE Outboard
                      I am thinking of buying the 6Y5W00886400 off of E-Bay. It is listed as a dual motor kit. Can I use this on my 1995 250HP Yamaha?
