I have a 25 hp elect start 07 yamaha on a carolina skiff. I want to change it to remote steering ...My motor is 25ESH ..serial 6L2K S 1024831....What parts do I need to make this conversion.....should I add engine gauges to the console?....I know that there is a steering bracket that attaches to motor that I can't find..Where do I get that bracket......I'm pretty handy...What tools do you need to make this change? ...I have a good Idea, but I want to make sure before I buy....would I need a Remote Conversion Kit?
tiller to remote question
You would need
6L2-48501-11-00 Remote attachment kit
689-61350-02-00 Steering guide attachment
6J8-48511-51-4D Steering Hook
703-48230-15-10 Control Box
order 2 control cables, MAR-CABLE-xx-SC(replace xx with length of cables needed)
For the key switch and choke to operate from control box you would need:
(1)6L2-42725-50-00
(1)6L2-86111-00-00
(1)682-86117-00-00
(1)6L2-86115-00-00
(1)98580-05008-00
(2)92990-05600-00
(1)90480-10155-00
(4)98508-04008-00
(4)92990-04200-00
(1)6L2-86112-00-00
(3)97013-06012-00
(3)92990-06100-00
(1)93210-03261-00
(1)6L2-82590-00-00
(1)6K3-82557-00-00
No the 703-48207 is push to open throttle, 10 pin main harness with power trim switch.
703-48230 is pull to open, 7 pin main harness and no trim.
Thanks for your help......Can you tell me where this model number comes from....ESH ...6L2K S 1024831....When I'm looking up parts this model number never comes up...the dealer tells me that it is a bad number.....I want to modify what I have already done....
It's a 2007 25hp elect start, short shaft and tiller control.
Yamaha Outboard Parts 2006 and Later 2-stroke 25ESR 6L2K-1018361
Originally posted by bguess View PostTiller to remote on Yamaha 30 MSHA - 6J8-S-112016
No electric start or choke wanted
just steering and throttle.
Regards,
REMOTE CONVERSION PARTS
Regards,
The Rigging Guide is the only source of information on control box installation. The control box installation is about the same except for electical and the main harness just plugs into harness on motor.
Originally posted by jeff180 View PostI've got a new 25esh model #6L2KS 1042060 from y'all recently. What parts do I need to convert tiller to remote? I do not want key start or electric choke. Will the parts mentioned in the previous threads work for this newer model #?
Jeff
689-61350-02-00 Steering arm
6J8-48511-51-4D Steering hook
701-48101-51-00 701 Side mount control box
(2) MAR-CABLE-xx-SC throttle/shift cables
ÂÂ
