New motor stuck in reverse
  • New motor stuck in reverse
    Anyone,
    I'm having problems with an essentially new Yamaha LZ200. It worked fine for a couple of days but now, whenever the motor is started, it is stuck in reverse and will not shift out of reverse. I'm running it on an Angler 2600cc. If anyone has any suggestions, I'd truly appreciate them.
    motor shouldnt start in rev , sounds like your neutral stop is loose and also hindering throttle from moving.
    rem 4 blk screws, move shfter F or R, lift off cover,rem 4 mount screws, lift out shifter, rem blk cover and you might have to remoce cables to access switch....look for the brown wired switch.
      Originally posted by kelbo2000 View Post
      Anyone,
      Since it's new, why not take it back where you bought it and make it their problem?
      Tim
        New Yamaha motor
        Problem is, I moved and now live and work in Ghana (West Africa). So, unfortunately, I'll be doing any necessary work on the motor.
          Check the shift cable connections on engine, the shift cable may have popped out of holding bracket in lower engine cowling.
