recomendation prop
  • recomendation prop
    2 stroke 2003 yamaha 50 on a carolinia skiff 17dlx with 10x15 g prop will only turn up 5000rpm 1 person in boat, wont plane with 4 lite persons in boat what prop recomandations. thanks FRANK
    Drop down to a 13 Pitch. You will increase rpm's to about 5400-5500 and will help to plane out better.
      my local boat dealer said my 10x15 was the lowest pitch prop avalable, what prop and part number do you recomend.
        If you have a aluminum prop then 6H5-45945-00-EL 10 1/4 x 13.
        If you a stainless steel then MAR-GYT3B-03-13 10 1/2 x 13
