Wiring diagram
  • Wiring diagram
    Hi need a little help with a wiring diagram. Just getting ready to hang a new 2006 F150 and don't want to mis-wire it. Installed is a new single key switch with alarm, 704 binnacle throttle with PTT, 10 pin wiring harness , Digital tach and a fuel management gauge.
    I will email you what I have.
      Hi need help with a wiring diagram. Just bought 2 new F200BETX and FL200BETX and don't want to mis-wire it. c/w Digital tach ,speedometer and a fuel management gauge.
      Thanks.
      dragonmount1@yahoo.com
        Here is diagram for twin engines with Multifunction digital gauges
          yamaha f150aet
          Hello. Is there a chance you have a wiring diagram for the f150aet? I am trying to connect 2 round digital tach, speed and fuel. I get left with spare wires when I connect color to color that I am guessing are for GPS speed, fuel tanks etc. Where do the red wires on the gauge go? there are no red wires on my harnesses.Do I connect to possitive?also I see more than one black wire. Is that for fuel sensors? thank you for your help
            Not sure if European models are same as US models or not,
            6Y5_704 Wiring.pdf
              I'm doing the same thing as you - but I can't find the engine side plug for the tach ! Where did you find the engine side tach connection; bow or stern side of engine, or port or starboard side?
              Kevin
