Need advice on Yamaha/Lowrance engine interface
  • Need advice on Yamaha/Lowrance engine interface
    I just bought a Lowrance LCX113C and want to know if I can use the Lowrance engine interface cable to monitor the engine parameters on the LCX113C. I have a 2003 F225 4cycle outboard, will it work?
    Mike
    No, the 2006 and newer models that will use Command Link gauges may be able to interface but I don't think the 2003 will. Contact Lowrance they should be able to tell you what it will interface with.
