shifting problem
  • shifting problem
    Any suggestions on where to start looking for the problem? I hit something while running wide open and now I cannot shift the motor into reverse and the motor makes a clanking noise while in neutral. The motor will shift into forward and run. After I trailered my boat I spun the prop and it roatated but made a clanking sound on each rotation. This is a 25hp yamaha four stroke outboard. Any suggestions would be appreciated.
    Remove the bottom drain screw in lower unit to see there is metal in lower unit oil, if metal there then it has damage inside lower unit.
