Compression good, what are the most common causes for an engine running poorly at all speeds, fuel or ignition?
200 HPDI missing at all speeds
Either one and more, the fuel injected engines have sensor that can also cause it run bad.
The debris that clogs the VST filter(2 micron) is very fine and passes right thru the RACOR(10 micron).
I experienced the same problem and it was likey due to ethanol cleaning the inside of my aluminum tanks.
FWIW, the VST filter is a 200 hour mait. item.
