Water Pressure
  • Water Pressure
    Can Someone Tell Me Where To Hook Up The Tube For A Water Pressure Gauge On A 2005 60 Hp Yamaha,thanks
    Water pressure gauge is not recommended for the 60 and 70hp 2 stroke engines. They use a high volume low pressure cooling system and water pressure gauge doesn't show very much if any water pressure.
      Temp Gauge
      If A Water Pressure Gauge Is Not Recommended On A 2005 60 Hp,can I Use A Temp Gauge?if So Where Do I Put A Sensor
        can i put a temp gauge on ? where do i put the sensor
          Yes a temp gauge will work, the Yamaha temp gauge sensor threads into block next to thermostat.
            Water Pressure Gauge 200 saltwater s
            Water Pressure Gauge not working . Can someone tell me where i can clean out the hose?? to maybe clear out the sand or what ever maybe in there????
            richard r
              HI Richard, I will try to answer your question. Disconnect the hose at the back of the guage and at the other end, at the motor. Make sure the pick-up is clear of debris, then from the guage end of the tube blow the line clear.
              That should do it.
              If you want more response to your question, ask it as a seperate post, not as an attachment to someone elses' post. You will get better results that way.
              Happy New Year, Dennis
