which Yamaha unit, (speed,fuel, RPM, depth, ?), would be the best fit upgrade to replace the tachometer on my F115?
F115 Tach upgrade
What year F115 do you have and what gauges do you have now?
The motor- F115TLRY. The Tach is a Yamaha digital with boat trim icon at the top right, temperature and oil icons on the bottom and numbers 1 thru 5 on the right. A 10 pin harness comes out of the back. No other markings on the gauge except for a 97N stamped on the back. The motor is a 2000.
There really are no advantage for replacing tach, the new digital tach has a hour meter in it but not really worth the price to replace. If your tach is bad and need to replace it then order 6Y5-8350T-82-00 multifunction tach. The multifunction speedometer is 6Y5-83570-S5-00 and displays speed, fuel gauge, battery voltage, clock, trip meter.
ÂÂÂÂ
