Hi all! New to the site, and I could use some help. Before anyone says "try the search button", I did. I run a '93 250 TXRR. Recently there is a miss at idle, and it has a mind of it's own while running. Whether it's at the dock or under power, it will change change rpm without touching the throttle.
I've done the following yesterday:
replaced both fuel filiters
replaced plugs
checked coil packs for resistance and replaced one that showed none
ran motor with brand new fuel source
After all this it seems that the miss is actually more pronounced, and will actually stall the motor while at idle.
It seems to be electrical to me, and after close inspection of all the wiring I'm leaning towards the ECU.
Is there any kind of diagnosis that can be done to check the ECU before purchasing one?
Thanks in advance for any help, as it would be greatly appreciated...
Elf
replaced plugs
Elf
