I have a 1999 Yamaha F100 4-Stroke, 3 mounths ago I had water in the fuel. I cleaned fuel line, fuel/water separator, and carbs. Now the engine works fine in neutral but in gear at 2500 rpm it splutters and dies. If I open the throttle at max in one shot it goes fine and I can go from 3000 to 5500 rpm without any problem. Under 3000 it returns to splutter. I have tried to tune the pilot mix screw, I have tried a separate tank but i have not solved the problem . The guy of assistence that cleaned my carbs thinks may be a carb syncro problem.
Thanks for any help.
