I was running my 1987 40hp Yamaha 2 stroke close to WOT and then it started a loud tapping or knocking sound. It sounded like a bad valve on a 4 stroke motor. It vaired with RPM. I shut the motor down a called for a tow. When I got home I ran the motor on the hose and did not hear it. I checked compression and it was pretty good. It was 90, 90 and 89. I have ran it a couple more time trying to find the noise and have heard it again but not as bad. I have not taken it above idle since the first trouble. I am pretty sure it is internal maybe a rod, main bearing or bad piston rig. Anyone have a suggestion? I am thinking about disassembling the power heard to see what I can find. Looking for tips before I go in.
Motor runs fine other than the tapping sound.
Thanks for any help.
