I bought an 2000 Action Craft with a 2001 Yahama 115 a while back. The digital gas gauge has never worked, according to the seller. I check the sending unit with my volt meter and it reads 78 ohms. When I check the voltage coming from the console, I get a reading of 0.05 volts (pink wire and ground wire). When I get a reading between the pink wire and directly to the fuel tank I get 4.14 volts. Also, when I connect the ground wire coming from the console to the pink wire from the console, I still only get the flashing icon at the console.
Any suggestions?
Puzzled in South Louisiana
Any suggestions?
