Compression Checking on a Yamaha 2-Stroke ??
  • Compression Checking on a Yamaha 2-Stroke ??
    I've been taught to take compression on a warm engine, with the plugs out and grounded.
    A recent venture into Polaris 2-stroke jet skis, I learned that it is better to take compression on a STONE COLD ENGINE with the plugs IN the cylinders not being tested ,-and the plugs grounded.
    The engine will rotate faster-(believe it or not) and since cold you have a repeatable base line to establish norms.
    I've tried this procedure and the above is true.
    What does the Yamaha community have to suggest about this procedure ?
    Also.....in jet skis "Piston Wash " is monitored. That's the areas around the outside of the piston top that is "washed" by the fuel. Viewed through the spark plug hole---it looks like small c's about the size of your fingernail, or so.
    Not enough wash and the engine is running lean(hot), thus possible burning a hole in the piston. Wash is con*****ed by carburetor adjustments.
    Comments please......
    Cold compression test is the norm for 2 and 4 stroke engines with throttle open. Outboards don't have the carb adjustments like the PWC engines and use a different fuel system and you wont always see the clean spots on piston at intake ports like the PWC engines.
      Thank you for the reply
