If don't have gauges then order a 6Y5-83553-N0-00 gauge wire harness and connect to key switch. If its a Yamaha tach just match wire colors, if it's not Yamaha connect green wire to sender terminal, yellow wire to ign terminal and black wire to ground terminal on tach.
