tilt trim fixed along with great info. thanks guys
  • tilt trim fixed along with great info. thanks guys
    Wanted to say thanks to you all for the input on my questions on the tilt trim problem: rebuilt the rams, new motor and new battery. now i tired a api motor first and it messed up with in 5 to 8 up and downs of the motor. but parts from here worked great and the seals and o rings fit perfect. but she works. and i will now order and change the water pump and thermostat's as well. and advice from you all ill stick to the yama lube.
    thanks again
    work all day and play all nite
