Yam 80 (1984)
Starts and runs great until i try to go 4000 and above, then overheat warning comes on and rev limiter cuts in, leave to idle for a minute then all is fine until 4000 again.
has had a new block and gasket/impeller and sleeve and gasket/temp sensor,timing has been set top and bottom end.
I removed the stat on the last run to see if that was at fault but still the same.
