I have a 92 115 2 stroke. It will start right up and run without a problem. Sometimes after letting it sit a while not running (15 minutes) it will restart run for a second then stop, and not restart again as it has no spark. Some days it runs and starts without a problem others it will not stop spark.
Im thinking the CDI unit needs to be replaced but what part of the mechanism.......magneto, pulser, etc.?
Has anyone come accros this before? Its odd how it will sometimes work perfect and others not so much, I assumed if it was CDI it would not work all the time, not part time, and I dont think it would be a loose wire because the only thing I touch is the key and it works and does not.
I almost wonder if it is not some sort of kill device the shuts it down (kill switch is fine)
Any info would be appreciated.
