My motor shut down totally doing 4000rpm it did not even go into limp mode .
The guages went dead
I did get a flickered warning and an alarm
I could not raise the leg
Battery is fine and the power leads to the motors are fine ,I even flick over to the other battery as I have twins .
I hr later I tried again the motor fired up and appeared normal I went back up to 4000rpm for five minutes then it failed again same way this repeated three times .There where no warnings on the YDS and back at the dock I revved up to 2000 rpm it fluctuated on its own up and down .I think the ECM might have a problem any ideas?
