CONTROLS/ 10 pin plug
  • CONTROLS/ 10 pin plug
    I have a newer yahmah control binnical, the plug that coneects to the motor is a 10 pin round connection. Will this work conncet to a 1990 250, if not is there an adaptor that will allow this to work?
    Yes the 10 pin main harness will work on the 250. If you have binnacle controls you will need a switch panel(704-82570-08-00) which the 10 pin harness plugs into.
