Hi, I have twin 1989 Yamaha 130s, I have an alarm going off and safe mode at higher RPMs after a few mile run. Water pumps have been replaced in the last year or so and I have a good telltale. My mechanic was in the boat at the end of last year and said the motors are not getting hot and that I have a bad sensor so I tested the sensors in a pan w/temp gauge and all close around 180-190 degrees. I don’t think the motors are getting hot and I cant seem to isolate which sensor is going off so this last Saturday, I ran the boat hard to get the temps up and when the alarm came on I stopped the boat and checked the heads immediately with a IR Gun and the temps across the heads where (127 & 111, 88 & 90 Degrees F)
So at this point I can not figure out why the alarm is going off and the motors are not hot?
Any input would be appreciated.
