Digital speedometer and fuel managment gauge wiring
  • Digital speedometer and fuel managment gauge wiring
    I've recently bought on ebay a digital speedometer and a digital fuel management gauge both single engine. These are the kind with the dipswitches under the rubber "cover". The wiring diagrams were off course not included. Could someone send me a copy of the wiring diagram for both gauges?
    Thanks a lot.
    I emailed it to you.
      Thanks, this is the information I was looking for.
        Hi Boats.net
        Would you please email the wire diagram to me as well. I have the digital speedo and multifunction tach with a 704 single con*****er and a 250 hp HPDI.
        The gauges work fine except there aren't any lights on the guages. In other words, I can't read them at night. One of the many wires coming out the rear of those guages must light them up for night viewing.
        Paul
          all the blues need to be hooked into your lighting system and blacks next to the blues need to be grounded.
            Could you be so kind to email it to me as well.
            kajtekpis@iprimus.com.au
            Kind Regards
            Voitek
              Thanks JB123
              I will try your suggestion
              Paul
                Thank you.
                dragonmount1@yahoo.com
                  digilal speedometer
                  would you be so kind to email me also thanks.
                  jandsf@netscape.com
                    wireing diagram for F250, square gauge, 2006
                    Hi
                    Can someone tell me where to find the wireing diagram for a F250, 2006, square gauges..fuel, speed, tech and such...I have all the modules, but no diagram. Much appriciated...Thanks
                    jck_wilson@yahoo.com
                      2002 225 yamaha 0x66 digital gauges wiring?
                      I have the Digital Tach and Speedo. Could you also send me the wiring diagram for hooking them up? kpaulk@nc.rr.com
                        115 wiring diagram
                        Please send me the wiring diagrams for the digital speedo and tacho.
                        Thank you.
                        jeff.wooldridge@sappi.com
                          Hello I am new to this forum and this is exactly the thread I was looking for, I too have the yamaha digital gauges and none of them light up in the dark. Would it be possible to get the wiring diagram as well so I could trouble shoot this problem.
                          Thanks.
                            You have two choices, inthe middle of the gauge power harness(one between ignition switch and gauges) you will see a short blue wire and a yellow wire. If you connect the blue wire to yellow wire backlight in gauges will come on when turn ignition key on. If you connect the blue wire to navigation light switch in boat the backlights will come on when turn boat lights on. DO NOT connect blue wire to both key switch and boat light switch, check all blue wire connections at gauges first to make nothing but gauges are connected to blue wires.
                            Here is guides on them
                            6YRW0035E1_F1 Installation Guide.doc
                            Yamaha FM Gauge.doc
                              Excellent, Thank you I was able to go out to my garage and get it working immediately.
                              Thanks very much.
