After running for about 30 minutes today I slowed down to look at an alligator. The engine died. Not even a "click" when I turn the key (Yamaha PRO50/1989) on the 703 control box. Trim switch works normally. Battery is good, connections at battery are good and appear to be good at the starter (no corrision and they are tight).
Where should I start? Neutral Control Switch or and work towards the starter or the other way around. I was in the 703 control box yesterday replacing the trim switch, hope I didn't do something inadvertent to the neutral switch.
Thanks,
Thanks,
