02 225 4 stroke chugging at low revs
  • 02 225 4 stroke chugging at low revs
    Ok, Novice here,
    before I go fo for a beating at the dealership, can anyone give me some color on my problem.
    When motor is engaged at low speed, engine chugs and shakes a little at higher revs and up onto plane no problem it flys.
    500 hrs on engine. Regular maint.
    Should I clean injectors?
    I just put some seafoam in.
    Any Ideas welcome.
    Mark French
    If it runs good at wide open then the injectors are probably ok, it needs to tested to find idle problem.
