Working on a problem where oil isn't pumping from the main tank to the engine tank. Swapped out the level sensor with a new one, tested operation and found that oil doesn't pump until the alarm level is reached. If I slowly lower the float from its top position, the pump in the main tank never kicks in. Once I get to the alarm level, my helm alarm sounds and the pump energizes. Pump works with the emercency switch. Before I spend the bucks, I'm thinking the problem is in the CDI unit. Any thoughts?
John
John
