I have a Yamaha F200 TRXB that has a warning buzzer problem.When starting the engine from cold,approx. 5 minutes of idling the warning buzzer will sound.If I turn the engine off then restart the buzzer will not sound again.Now while under normal operation everything seems to be ok.
If the engine idles for a long period of time after the first start up,approx. 10 to 15 minutes the warning buzzer will sound sound again.
I have already installed a new water pump assembly,and new thermostats.And with the use of a Laser Heat temp sensor gun the engine appears to be running at normal temperature. There is water coming out of the little squrit tube from the side,and feels just warm.
Does any body have any idea what might be going here ??
Thanks for any help or ideas.Service agents are not an opition,we're located in the out islands of the Bahamas.Thanks again for any input.
