Yama 200 fuel pumps leak when primed
  • Yama 200 fuel pumps leak when primed
    I noticed when I pump the primer bulb that fuel leaks out of the area where the fuel pumps are pieced together. Is that normal and does it stop after you get under way? Does the fuel pressure the primer bulb creates that makes them overflow?
