Rigging 03 F115
  • Rigging 03 F115
    Hello, I will be rigging the F115 on a pontoon, The boat has a generic teleflex binnacle and cables.
    I will be needing the harness(s)
    There is a 10 pin round and a 4 pin square with only 2 wires on the engine. What is the two wires for? Tach? Will I be able to use the teleflex control?
    The Teleflex controls will work make sure it is set up for push to open throttle. I would suggest a new switch panel(704-82570-08-00) and 10 pin harness 6X3-8258A-00-00 16ft or 6X3-8258A-10-00 20FT OR 6K1-8258A-40-00 26ft. The four pin connector is for oil warning and temp warning lights in tach and trim gauge signal. If you are using trim or tach with warning lights order 6Y5-83653-00-00 16ft Trim/Oil harness and 6Y5-83553-N0-00 gauge harness.
      Thanks for the info. I friend has a main engine harness from a 1998 yamaha v-6 200 10 pin. Will this work for my 2003 F115, I will still need to order the other parts from you. Switch / trim harness / gauge harness. I have the motor, will be picking up the pontoon this week, and then work (fun) begins.
      Thanks for any info.
        The 1998 main harness(10 pin harness) will work, Yamaha has not changed that harness.
          Thanks for all the help, 1 other quick question?
          There is a small hose routed to the rubber bushing where all the wires / cables come in too the motor, What is the small hose for? Vent, Fuel return to tank?
          Thanks for you help
